Hello Everyone
i got problems for my machine plasma cutting burny 10 lcd plus, and the status on LCD was "STOP--EXTERNAL STOP ACTIVE". and can you tell to me how to fix it?
Problem EXTERNAL STOP ACTIVE on Burny 10 LCD Plus
- tnbndr
Re: Problem EXTERNAL STOP ACTIVE on Burny 10 LCD Plus
Did somebody push that larger red button on top of the panel? To reset you need to turn it counterclockwise. You will hear it click back on.
If the button is not pushed then something in that circuit is bad, telling the machine that it has been activated.
Good Luck
Good Luck
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
I'm with Dennis and if the red button was pushed in and you turn it so it pops back out and you don't here anything or the error message does not go away there may be a Reset button on the screen that needs to be pushed and you may have to re-zero the XYZ axis' before you can begin cutting again.
Is there possibly more than 1 estop button? Maybe on the opposite end of the table?
