Hi HC - I have opened your file and this is what I see.HCmillertech wrote: ↑Thu Apr 20, 2023 7:11 pm You seem to be my teacher on here. Thanks you. I have a question for you
> my son is making something and drew it in solidworks and saved it as a dxf.
> when i open it in inkscape it seems to not like it at all. It wont fill
> and really just acts weird.
> Anyway you could tell me how to get the file ready to cut?
> I attached the file
> Thanks!!
SolidWorks dxf problems
Re: SolidWorks dxf problems
Here is the edited file.
PS
I opened your dxf with Inkscape to have a look. Here is what I found. Let me know if you have specific questions about editing your file with Inkscape and I will show you a step-by-step sequence of editing it.
PS
Thank you so much for helping me. He said it was drawn in 3D so maybe this is what happened.
Ok I wanted to open the fixed file to compare but I am getting this error.
I would like to fix this in inkscape if I can. I ungroup but I am still not able to select the lines to delete them. If you could help me with that process it would be awesome.
Thanks again
Thanks again
- Attachments
- Capture.JPG (26.46 KiB) Viewed 834 times
First of all, I am using Inkscape Version 1.2.1HCmillertech wrote: ↑Sun May 14, 2023 9:37 am Ok I wanted to open the fixed file to compare but I am getting this error.
I have my Document Properties set set to inches.
Great info David. In your red text I am trying to see what the node looks like when not joined and when it is joined. What is the difference. It is hard to tell by the screen shot.
T.J.
PM Sent.HCmillertech wrote: ↑Sun May 14, 2023 9:37 am Ok I wanted to open the fixed file to compare but I am getting this error.
Thanks again
