PlasmaCam font issue
- 1/2 Star Elite Contributing Member
For some reason I am unable to get a font in ttf form to show up in Design Edge?
- Joe Jones
Re: font issue
Do you have BASIC or ADVANCED DesignEdge software, and which version are you running?
Franklin, KY., USA
Samson 510 & 4x4
CreatBot D600 PRO 3D Printer
16 Lasers
FREE DesignEdge Training!
Samson 510 & 4x4
16 Lasers
- Joe Jones
Re: font issue
When you install a font onto your PC, that does not necessarily install the font into the folder that DesignEdge uses for its fonts. It is best to drag and drop the unzipped .ttf font directly into the PlasmaCam FONT folder.
Open
C:
Program Files (x86) (folder)
PlasmaCAM (folder)
FONTS (folder)
Drop the font into that group and close the folder. The NEXT TIME you open DesignEdge, the added font will appear in the software drop down list of available fonts.
Open
C:
PlasmaCAM (folder)
FONTS (folder)
Franklin, KY., USA
Samson 510 & 4x4
16 Lasers
Samson 510 & 4x4
16 Lasers
Re: font issue
From Design Edge, try looking in the Windows folder.
Re: font issue
OK, so the file is in design edge windows box checked and still does not come up.
- Joe Jones
Re: font issue
Did you INSTALL the font onto your computer, or just ADD it to a font folder?
What is the name of the font you are trying to install? Can you attach the file to a reply? I will see if I can install it onto my PC.
Franklin, KY., USA
Samson 510 & 4x4
16 Lasers
Samson 510 & 4x4
16 Lasers
Re: font issue
I have tried many more fonts with same result the font is Rosanna in 1001 free fonts
- Joe Jones
Re: font issue
I believe you! I tried to load several fonts. They all load onto the PC and they all show up in WORD, but they CANNOT be added to DesignEdge!
It is time to let PlasmaCam know about this!
Franklin, KY., USA
Samson 510 & 4x4
16 Lasers
Samson 510 & 4x4
16 Lasers
Re: font issue
I tried to install this font into Design Edge, and although it does show up on the Plasmacam Fonts folder it does not show up on the fonts list when I open Design Edge. I installed it into both the Design Edge Fonts folder and the Windows Fonts folder.
The windows font version does show up in Inkscape.
So the work-around is to type your text in Inkscape, then "Path, Union" to eliminate crossovers, save as dxf R14, and then import to Design Edge for use with your project.
Re: font issue
If you wish to fit the text to a curved path, do it in Inkscape and then save as dxf for import to Design Edge. Trying to fit to curved path using Design Edge will not produce good results using this particular font.
- Joe Jones
Re: font issue
I notified PlasmaCam of their glitch, that the new version 4.57 will not allow ANY font to be added to the DesignEdge font library.
I see a version 4.58 in the near future
Franklin, KY., USA
Samson 510 & 4x4
16 Lasers
Samson 510 & 4x4
16 Lasers
- rdj357
Re: font issue
The problem is not with Design Edge - the font files for Rosanna say TTF but they are incompatible for some reason.
The font came with both OTF and TTF files so I uploaded and converted the OTF files to TTF using Convertio.co and they will work fine in Design Edge.
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
- Joe Jones
Re: PlasmaCam font issue
I saw the OTF files but I have not worked with them. However, NO FONTS will load into my 4.57 DesignEdge. So I will continue to believe it has something to do with recent changes in the micro-security-updates that PlasmaCam seems to view as a priority over adding actual design features that their customers crave.
I am not bashing PlasmaCam or the owner of DesignEdge software. I am simply stating a fact. DesignEdge MAY once have been the cat's meow for design software, but I am now looking at other options and quite frankly, there is some SERIOUS competition out there for drawing VECTOR ART.
Most software ditched the old coordinates system. Some use on-screen adjustable dimensions. Some are able to change the FONT of text placed into a design by selecting the text! Some offer LAYERS! Some give you options to fill in a design with COLORS for presentation to a customer. Some let you draw a horizontal lin and it will pick up the "inference" point to show you where to stop and make a right turn to intercept that end point below.
There are a hundred different and awesome features that could be added to DesignEdge to RETURN it to the top choice in Design software, but sadly, DesignEdge is being left behind, as it sits with its arms crossed and heels dug in, refusing to acknowledge that 1980's software that once excelled, has been overtaken with much better options. I don't blame them though. They know that PlasmaCam owners would not respond well to a $10,000.00 MEGA-UPGRADE software package, and I am fairly certain that version 5.xx would come at a price in that neighborhood.
They are not going to improve DesignEdge unless it translates into millions of dollars in sales. I would GLADLY pay $98.00 for each REAL feature they add. Doing the math, if 50% of PlasmaCam owners each bought the additional features at $98.00 each as they are released, I think PlasmaCam would see a nice cash flow. for whatever reason, they chose instead, to raise the price of the various table components to "I'm gonna SELL thing thing!" levels. $500.00 for a carriage or gantry motor? $2,000.00 for a carriage assembly?
I use Lightburn software for certain tasks, simply because it does some things BETTER than DesignEdge, and that is a $60.00 program designed for the guys and gals with lasers. I use CRICUT software to color in designs. I use VECTOR-Q on my iPad to do things DesignEdge cannot do, such as drawing in bridges to eliminate islands. You can draw them with an Apple pencil and then automatically combine the entire design in one action! I am learning Fusion 360. I have Google SketchUp, and DesignSpark Mechanical too.
I guess DesignEdge just feels that we can fill in the shortcomings of DesignEdge by using other software, but isn't that abandoning the original concept of DesignEdge, that of being an ALL-IN-ONE software package?
Franklin, KY., USA
Samson 510 & 4x4
16 Lasers
Samson 510 & 4x4
16 Lasers
- Joe Jones
Re: font issue
Thanks, Robert. I suppose the extra step is not TOO troublesome. I have to wonder though. If a font qualifies as a "TrueType Font" (.ttf) shouldn't it BE a TrueType Font before it can be given the ".ttf" extension?rdj357 wrote: ↑Mon Mar 13, 2023 9:07 am The problem is not with Design Edge - the font files for Rosanna say TTF but they are incompatible for some reason.
Franklin, KY., USA
Samson 510 & 4x4
16 Lasers
Samson 510 & 4x4
16 Lasers
Did the OTF file conversion and now it works great, Thank You all for the help and I did let Brian know of the issue and let Jason know as well.
- Joe Jones
Yes, there are work arounds... Convertio.co does convert the file to a true .ttf file that you can then install into DesignEdge.
Franklin, KY., USA
Samson 510 & 4x4
16 Lasers
Samson 510 & 4x4
16 Lasers
Re: font issue
Thanks Robert! I knew if anybody would know what to do here, you would be the guy. I'm using 4.53 and could not get it to work, so I don't think it is version dependent. Just a problem with this particular font.rdj357 wrote: ↑Mon Mar 13, 2023 9:07 am The problem is not with Design Edge - the font files for Rosanna say TTF but they are incompatible for some reason.
- Joe Jones
Re: font issue
Unfortunately, the same problem seems to crop up with ALL fonts in v4.57. I can't get any .ttf font to load into DesignEdge.
Franklin, KY., USA
Samson 510 & 4x4
16 Lasers
Samson 510 & 4x4
16 Lasers
- rdj357
I have no problems with adding or using TTF fonts in v4.57. What exact issue are you having? It seems you got the font mentioned here to install and work???
Also, I have had other TTF files that did not work. It happens - font designers aren't always the most meticulous about details. It's rare but it happens.
Robert Johnson
- Joe Jones
I was only able to install the Rosanna.ttf font into DesignEdge AFTER running it through Convertio.co. Other .ttf fonts randomly chosen from (insert name of free font site here) will not install in 4.57 either. I do not know why!rdj357 wrote: ↑Mon Mar 13, 2023 8:42 pm I have no problems with adding or using TTF fonts in v4.57. What exact issue are you having? It seems you got the font mentioned here to install and work???
Franklin, KY., USA
Samson 510 & 4x4
16 Lasers
Samson 510 & 4x4
16 Lasers
