hey i have a question
i have a diy table and am looking to get a little more setup with my oroma thc. i currrently am running mach3 and have my thc set at 127v
on my plasma table. is there any settings that i can use for lighter sheet metal upto at least 1/4' plate.
thanks in advance
Proma thc settings for light metal
Re: proma thc
yup, use a higher voltage and lower feedrate
Re: proma thc
The best thig to do is create a chart for you to use for the different metals you cut. The voltage will vary with different plasma units You can use other charts (Hypertherm manual has them) as a guide for getting you in the ball park. Here is a video on haw to check the voltage and make a chart to keep. This is for another THC but the info will help you do yours.
https://youtu.be/EyZJVMtzKzY
Re: proma thc
Arc voltage setting will need to be changed when changing material thickness, amperage, or cut speed in order to maintain a proper cutting height and Tom has the right idea making your own chart. Will be very beneficial to take the time to do it and if you only cut a few different thickness of material it won't take long at all.
