Having a problem .
The THC works perfect with the hypertherm normal consumables , But when I try to use the fine cuts torch moves up while cutting till I hit stop . Have played with everything I know to fix . No change . This is a premier plasma table and using hypertherm 45xp , using sheetcam to mach 3 , can someone help ? Thanks
Scott
Proma 150 THC 45XP fine cut problem
Re: Proma 150 THC fine cut problem
Did you look at the chart for the correct arc voltage for fine cut and metal thickness. It is different than a 45 amp nozzle.
Thanks , I have not lowered voltage as much as chart says, usually bad things happen when I change voltage that much . currently cutting at 99 volts book says 78 , I will try and see what happens .
Thanks for the pointer looks like for 14 gauge 58 is the magic fine cut voltage .
good job.
thanks for the follow up reply
Re: Proma 150 THC 45XP fine cut problem
Don't be hesitant to change that arc voltage, you can always got back and the chart numbers are good starting points but not gospel.
Here is a video on how to find the correct voltage for each material you cut. This was for a Price THC but is the same for all THC units. Run the tests and create your own list for your unit.
Thanks , helpful video , I need to go through and make a set of tools for the fine cuts now that I know how to set up .
