A person I work for has tasked me to try and get machine working.
Hypertherm cutmaster 65
Plamacam DHC+
Talked to plasma cam they said cut wiring, so I checked all wiring inside machine and to control box everything ok.
What I found checking things when you go to diagnostic screen when idle reads 1.19 volts when you pull trigger no change, not sure what to do.
Any help would be great, thanks.
Chris
Plasmacam arc voltage problem
Re: Plasmacam problem
HI Chris Well your at the right place many Plasmacam users here so help is on the way.
- rdj357
Hi Chris,
I answered your post over in the Owner's Community as well but this information is a little different than what was posted there. We can continue the conversation and I'm happy to help either place. lol
For posterity, here's what I replied over there:
The trigger should be zip tied. Is your torch control cable installed correctly?
If you are saying that when you check the trigger box in diagnostics, the torch fires but the voltage does not change then there is a problem with the torch control cable (broken wire to resistor inside, not plugged in fully and rotated correctly, not wired correctly in the Hypertherm) or with the controller itself (rare but not impossible).
When you say it won't cut - are you saying that it stops and gives an error? If so, what is that error?
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
In diagnostics screen with torch trigger not activated it reads 1.19 volts when you activate trigger there is no change in volts. I check all wiring inside machine and cable going to control box and everything checks good. Before I started trying to trouble shoot things it would cut for about 4" then stop.
As for error codes it said torch cutting signal was not detected.
- rdj357
OK - it sounds like the controller is not getting the arc voltage feedback from the Hypertherm to the controller. There are resistors under the heat shrink on the torch end of that cable that are quite fragile and can be broken.
Here is a diagnostic sheet for the torch control cable to help troubleshoot that cable.
Robert Johnson
ok, I will check that out per the sheet you provided. thank you for your time and if I need more help after that check I will post another question.
thanks again and have a great day.
- rdj357
No problem, happy to help!! My email is Robert@490Creations.com in case you have a more in depth problem or chatting would be easier - happy to give you my cell in email.
Robert Johnson
I will look forward to hearing if you were able to resolve your problem. Good Luck!
