Hypertherm 45 amp Torch on Powermax 65?
Can I run this Hypertherm 088167 Duramax Lock Machine Torch on a powermax 64 at full power?
Blackwater Anvil LLC
DynaTorch XLE 5x10
Hypertherm Powermax 85
Lots of Lincoln welders
DynaTorch XLE 5x10
Re: 45 amp Torch on Powermax 65?
I am pretty confident that torch is not compatible with the Powermax 65. You will want to get the Duramax torch.
Re: Hypertherm 45 amp Torch on Powermax 65?
I am confused, This is a Duramax Torch ? correct ?
DynaTorch XLE 5x10
DynaTorch XLE 5x10
That is the Duramax Lock torch which is different. I believe you can swap the consumables out on that without having to cycle the power to the power source where with the standard Duramax you can't.
Ok, that makes sense
Thanks for your help
DynaTorch XLE 5x10
DynaTorch XLE 5x10
