Save as DXF from Inkscape for SheetCAM
How do i export from inkscpe to dxf to open in sheet cam
Re: Convert image to plasma cut file
Drop down the File menu - click on Save - when Save dialog box appears drop down the Save is Type drop down menu - select Desktop Cutting Plotter (AutoCAD DXF R14) (*dxf) option - name your file and choose a save location and you should be set to open that dxf in SheetCam
Re: Save as DXF from Inkscape for SheetCAM
Why.
I have been saving as SVGs and using sheetcam and cutting for a few years like this.
It has been my experience that for the same drawing exported from Inkscape, the svg will have less nodes than the dxf - resulting in possibly a smoother cut.
It probably depends on the specific cutting table and the particular design being cut. I know that fellow member ROKCRLER has mentioned that he get smoother cuts when excess nodes are edited out using Inkscape. There was some discussion about this in the thread below.
viewtopic.php?f=98&t=34453
- ROKCRLER
I definitely see better cuts with reduced nodes, especially when cutting 16ga and thinner since i usually cut fast on those. Thicker than 11ga i dont worry too much because those parts are usually welded pieces for the rock crawlers i build. Art stuff i try to clean up as much as possible.adbuch wrote: ↑Wed Jan 04, 2023 7:18 amIt probably depends on the specific cutting table and the particular design being cut. I know that fellow member ROKCRLER has mentioned that he get smoother cuts when excess nodes are edited out using Inkscape. There was some discussion about this in the thread below.
4x8 Dynatorch
PM85
~Mo~
PM85
~Mo~
I will have to try it. I actually cut out many of those exact ornaments with custom names using various fonts. They come out great. I think Command CNC has something in regards to tracking better for smoothness. I forget what Tom C. said about this.
