Here is a handy tool to check the mounted position of the Machine torch on your table or other things like the angle of a saw blade. Since it can be zeroed to any surface first then to check the angle of the tool to that surface, it is more usable than a standard level to look for the exact 90 degree setting. Small enough to used where mounting bracket may interfere with a longer units.
https://www.ebay.com/itm/363633029009?h ... SwK39hndeX
Handy Angle Finder Inclinometer
Re: Handy Angle Finder Inclinometer
Nice find Tom! I've got some similar from IGaging. I was using then on my press brake to check bend angles.
I do similar with my tubing bender which is a horizontal type
Good call Tom, I have a very similar unit and it works great for that and many other applications, I love it. I see this one is super affordable and magnetic which is nice. Definitely worth having
Also fun to play with when you are bored on a plane....
