DTHC-IV to DTHC-V upgrade
I just received a New DTHC-V card and I'm not sure if I got the right card. I do not want to install it until I'm sure. I am switching from a DTHC-IV. I requested the DTHC-V with Ribbon cable option. How does the DTHC-V connect to the UBOB? What I was able to find is it should connect through the 16pin ribbon cable (or direct with EBOB). What is the difference between the 2 DTHC-V card options? The card that I received will not connect to the ribbon cable.
Re: DTHC-IV to DTHC-V upgrade
You may be best to contact C&CNC direct on this question. Certainly curious to know what you find out if you could post back.
tom comes on here from time to time, but the candc forum is probably where you'll get the best and fastest answers.
https://www.candcnc.net/supportforum/index.php
actually scratch that, as I see you have an answer.
https://www.candcnc.net/supportforum/vi ... =24&t=3172
(you'll need to register there for a look).
Cross posted.
https://www.candcnc.net/supportforum/vi ... 190#p19190
