Hey everyone I am in the process of building an air scribe plate marker for my table. I understand the mechanics of it the hose routing and how to wire it. I’m just having a hard time figuring out the sheetcam and Mach 3 programing part.
I am using pin 16 on my break out board to a relay to trigger the solenoid to power the air scribe. I created a new tool in sheetcam made the tool number over 100. Now I need to get into post processing and I am getting quickly over my head.
I’m using a premiere plasma table and have that selected on the post processing section. All of the research I have done everyone seems to be able to select there machine with the plate marker from the drop down menu because I’m assuming its an option with there machine.
Is there a way I can add the plate marker to the premier plasma post process I have selected?
Or can I choose a generic plasma cutter and plate marker from the drop down menu? Id assume I can’t do that because id loose all premiers settings
Plate marker post processing help
Re: Plate marker post processing help
I don'd have a copy of the Premier plasma post processor. Could you send me a copy. I'll take a look and see if they have implemented air scribing.
Thank you I messaged you a copy also.
excuse me if I don't use the correct terminology I know nothing about post processing or g code.
again what I'm trying to do is create a plate marker tool in sheetcam that activates pin 16 through mach 3
function OnAbout(event)
ctrl = event:GetTextCtrl()
ctrl:AppendText("For use with ProTorch CNC Plasma cutting tables")
end
-- revision 3/2/07
-- Removed final safety move. This is now done in SheetCam
-- revision 7/10/05
-- Added new arc handling
-- created 27/10/04
-- Based on plasma1.post
function OnInit()
post.SetCommentChars ("()", "[]") --make sure ( and ) characters do not appear in system text
post.Text (" (Filename: ", fileName, ")\n")
post.Text (" (Post processor: ", postName, ")\n")
post.Text (" (Date: ", date, ")\n")
if(scale == metric) then
post.Text (" G21 (Units: Metric)\n") --metric mode
else
post.Text (" G20 (Units: Inches)\n") --inch mode
end
post.Text (" G53 G90 G40\n F1\n S500\n")
dist = 9999999
refdistance = 150 * scale
switchoffset = -0.20
bigarcs = 1 --stitch arc segments together
minArcSize = 0.05 --arcs smaller than this are converted to moves
end
function OnNewLine()
post.Text ("N")
post.Number (lineNumber, "0000")
lineNumber = lineNumber + 10
end
function OnFinish()
post.Text (" M05 M30\n")
end
function OnRapid()
if(math.hypot(endX-currentX , endY-currentY) < 0.001 and endZ < currentZ) then return end
dist = dist + math.hypot(endX-currentX , endY-currentY)
post.ModalText (" G00")
post.ModalNumber (" X", endX * scale, "0.0000")
post.ModalNumber (" Y", endY * scale, "0.0000")
post.ModalNumber (" Z", endZ * scale, "0.0000")
post.Eol()
end
function OnMove()
post.ModalText (" G01")
post.ModalNumber (" F", feedRate * scale, "0.###")
post.Eol()
end
function OnArc()
if(arcAngle <0) then
post.ModalText (" G03")
else
post.ModalText (" G02")
end
post.NonModalNumber (" X", endX * scale, "0.0000")
post.NonModalNumber (" Y", endY * scale, "0.0000")
post.Text (" I")
post.Number ((arcCentreX - currentX) * scale, "0.0000")
post.Text (" J")
post.Number ((arcCentreY - currentY) * scale, "0.0000")
post.ModalNumber (" F", feedRate * scale, "0.0###")
post.Eol()
end
function OnPenDown()
if(dist >= (refdistance/scale)) then
dist = 0
post.ModalText(" G31 Z -100")
post.ModalNumber (" F", 500 * scale, "0.0###")
post.Eol()
post.ModalText(" G92")
post.NonModalNumber(" Z", switchoffset, "0.00")
post.Eol()
post.CancelModalNumbers()
end
--[[ post.ModalText (" G00")
post.Eol()]]
if (preheat > 0) then
post.ModalNumber (" Z", cutHeight * scale, "0.0000")
post.Eol()
post.Text(" M801\n G04 P 0.5\n M802\n G04 P0.1\n M902")
post.Text ("\n G04 P")
post.Number (preheat,"0.###")
post.Eol()
end
post.ModalNumber (" Z", pierceHeight * scale, "0.0000")
post.Text ("\n M03\n")
if (pierceDelay > 0) then
post.Text (" G04 P")
post.Number (pierceDelay,"0.###")
post.Eol()
end
end
function OnPenUp()
post.Text (" M05\n")
if (endDelay > 0) then
post.Number (endDelay,"0.###")
post.Eol()
end
end
function OnNewOperation()
post.Text (" (Process: ", operationName, ")\n")
if (plungeRate <= 0) then
post.Warning("WARNING: Plunge rate is zero")
end
if (feedRate <= 0) then
post.Warning("WARNING: Feed rate is zero")
end
end
function OnComment()
post.Text(" (",commentText,")\n")
end
function OnToolChange()
post.Text (" M06 T")
post.Number (tool, "0")
post.Text (" (", toolName, ")\n")
end
function OnNewPart()
post.Text(" (Part: ",partName,")\n");
end
function OnDrill()
OnRapid()
OnPenDown()
endZ = drillZ
OnMove()
OnPenUp()
endZ = safeZ
OnRapid()
end
end
-- revision 3/2/07
-- revision 7/10/05
-- created 27/10/04
function OnInit()
else
end
dist = 9999999
end
post.Text ("N")
end
function OnFinish()
end
function OnRapid()
post.Eol()
end
function OnMove()
post.Eol()
end
function OnArc()
else
end
post.Text (" I")
post.Text (" J")
post.Eol()
end
dist = 0
post.Eol()
post.Eol()
end
post.Eol()]]
post.Eol()
post.Eol()
end
post.Eol()
end
end
function OnPenUp()
post.Eol()
end
end
end
end
end
end
end
end
function OnDrill()
OnRapid()
OnPenDown()
endZ = drillZ
OnMove()
OnPenUp()
endZ = safeZ
OnRapid()
end
In SheetCam go to Options->machine->post processor and select the 'Mach3 THC with scriber' post. Next click on the 'Edit post' button.
Near the start of the file are a number of configuration options. Use these settings:
useRef = true
refHome = false
refDistance = 150
refFeed = 500
switchOffset = 5.08
scriberX,scriberY,scriberZ to suit your scriber. The are the offset of the scriber from the torch tip.
scriberAxis = nil
This assumes your scriber is mounted to the Z axis on a slide that goes down when the coolant output turns on. In other words, pin 16 needs to be configured as the coolant output.
useRef = true
refHome = false
refDistance = 150
refFeed = 500
switchOffset = 5.08
scriberAxis = nil
