Hey Guys,
Do any of you run a voltage stabilizer / regulator on your plasma cutter. I might be having an issue with this interfering with my THC. Table is grounded. If you do did it help?
Mike
Voltage Regulator Stabilizer
Re: Voltage Regulator Stabilizer
Hey Mike, that shouldn't be needed. Are you having a problem that you are trying to solve by installing this?
What are the symptoms of your interference problem? It would probably help if you would describe in detail of your complete setup - plasma cutter, table, controller, software, etc. Photos might also be nice.
