This may not be plasmacam specific, but I'm hoping someone can point me in the correct direction. I'm using a Hypertherm Powermax 1000 with 40a fine cut consumables. While cutting aluminum (all I've really cut so far) I am sometimes getting slag blowing back and accumulating between the cup and machine shield. It is occasionally bad enough to catch on the work and drag it and screw up a run. Do any of you know where I should start with troubleshooting?
Thank you!
Jason Campbell
And another question... Slag buildup on consumables
- rdj357
Re: And another question... Slag buildup on consumables
Auto calibrate your height often if you have advanced height control. I use a little nozzle spray on the shield and nozzle, let dry and assemble. That seems to help too.
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
I've auto calibrated it several times. I haven't tried the spatter spray yet. I have some somewhere, I'll find it and give it a shot. Thank you
Here is some discussion from Jim Colt about ceramic anti spatter coating.
https://www.plasmaspider.com/viewtopic.php?t=23198
