I have built a new table 2 months ago and I now have the time to show you.
I used alot of bits from my last table including the gantry.
Here are some pictures. I made the sides higher so I can get bigger square tubing under the gantry. Compared to my other table which is not very good at all.
I will post more photos soon.
Mtw fdu.
New 2 x 4 table build
Camcutcnc 4 x 4 plasma cutter with UC 100 Motion Controller
Powermax 45 with Machine Torch
Bobcad V27 and Mach 3
Proma THC
Now with Rotary Axis
Laser cross hairs
Proma THC
Laser cross hairs
Re: New 2 x 4 table build
Growing as you go, I have done that to with different table shapes and sizes. Only you really know what is needed for your operation.
Couple more pictures.
Added a table for the computer and what the table looks like now with a job being cut.
Mtw fdu.
Mtw fdu.
Proma THC
Laser cross hairs
Proma THC
Laser cross hairs
Nice set up. I someday want to make a mobile table that folds out of the back of my welding truck. Someday
I only have a couple of things to finish off my table including levelling 3 corners and installing another guard/cover.
I will also be redoing my rotary axis to suit as well.
My original table gave me 650mm x 450mm but I could slide longer material through. My new table now is 1350mm x 650mm. I can still slide longer material if necessary.
Thanks for the comments guys.
Mtw fdu.
Mtw fdu.
Proma THC
Laser cross hairs
Proma THC
Laser cross hairs
Here is a video of my table. Just a quick walk around.
Mtw fdu
Mtw fdu
Proma THC
Laser cross hairs
Proma THC
Laser cross hairs
