Hello, I'm not focused on CNC, but I am focused on what kind of non-CNC table I can buy / build for plasma cutting. I've seen some vids where a table is open and has vertical slats that support the work being cut - but apparently the slats do not get cut up too bad from work going on.
Can someone help with terminology on this sort of table, plans, or purchase? What do you call a non CNC plasma cutting table please?
Plasma table that isn't CNC
Re: Plasma table that isn't CNC
Many years ago i had a pattern cutting table. Basically a magnetic drive wheel that moved around a premade steel part and cut a duplicate out on the cutting table. Worked really well actually.
Excellent, thank you
