Blue screen AVHC OK to Move testing
We have an older torchmate 4x4 with the "Blue Screen" AVHC I would like to test the "OK to move" switch since it doesn't seem to be getting that signal. Our unit follows the path correctly with the torch off and also takes right off if you shut off "OK to Move" in the AVHC and run a job. For testing, would I put an ohm meter on the "OK to Move" terminals on the AVHC or on the signal wire from the power supply to watch for a change in continuity? I don't just want to start hooking stuff up randomly. Thanks!
Re: Blue screen AVHC OK to Move testing
I would need to see the schematic wiring diagram in order to advise you as to the proper connections to test.
