dross
kellyschlarb
dross
Post by kellyschlarb »
I have a gofab plasma table. 14 ga hotroll sheet. cutting at 50 amps 85 lb airpressure lots of dross. got any ideas I m new
Scratch
Re: dross
Post by Scratch »
What's your speed?
Hypertherm torch?
Water table?
Got pics?
kellyschlarb
Re: dross
gofabtable and gofab plasma not sure on speed
kellyschlarb
Re: dross
send pics tomorrow
Re: dross
Cutting speed and cut height can influence the amount of dross on your parts.
Dragfluid
Re: dross
Post by Dragfluid »
As previously stated, speed and height. Also current, and CLEAN, DRY, AIR! :)
Do you have an air dryer inline?
PlasmaCam DHC2
Powermax 45XP
Tig
Mig
A hammer
mdwalker
Re: dross
Post by mdwalker »
Considering everything is operating as it should do the following:
As stated above, Make sure you have clean, dry air.
New consumables
Verify cut height is set correctly. Not by settings but by physically measuring the actual cut height.
Make sure your cut speed and power are set correctly for the material you are cutting.
This should get you in ballpark. From here do some test cuts at different cut speeds until you dial in the best setting.
When set correctly you should have very little dross. It also helps to know if you have high speed or low speed dross. If it is heavy dross and easily breaks off it is generally low speed dross. Try increasing your cut speed. If it is finer dross and hard to chip off it is probably high speed dross. Try lowering your cut speed.
Danny Walker
Walker Manufacturing
Tishomingo, Oklahoma USA
www.walkermfg.net
