Hi guys.
Running a hyperthem 85 with 45 amp fine cut consumables, water table on mach 3 control
Wondering if this is about as good as I'll see from it or if there is a way to dial it in even better.
Thanks for any help.
Fine cut on stainless 1.5mm sheet
Re: Fine cut on stainless 1.5mm sheet
Looks pretty good. Are you using lead in's? It looks like it may be piercing on the finished edge but you have little to no dross so it looks good.
2mm arc lead ins very happy with the haz and dross
Looks good. Are you using the Hypertherm recommended settings from the Finecut SS chart?
Sure am David
