Cleaning oil on cold rolled?
AKmud
Post by AKmud »
What is the preferred method to get cold rolled steel clean? I'm talking about the oil on the sheets from the supplier. I've tried acetone, brake cleaner, windex, etc... It usually ends up using a lot of cleaner and a few different towels to get pieces actually clean which eats into my bottom dollar. Is there a quick and inexpensive way to get the oil off? I was thinking of building a narrow vat to keep solvent in or something to eat the oil off.
abmetal
Re: Cleaning oil on cold rolled?
Post by abmetal »
I use lacquer thinner and a rag. Doesn't take much.
Allen
abmetal wrote: Sun Jun 28, 2020 9:42 am I use lacquer thinner and a rag. Doesn't take much.
Allen
I do the same. Only I use paper towels.
ScottRa
Post by ScottRa »
AKmud wrote: Sun Jun 28, 2020 9:32 am What is the preferred method to get cold rolled steel clean? I'm talking about the oil on the sheets from the supplier. I've tried acetone, brake cleaner, windex, etc... It usually ends up using a lot of cleaner and a few different towels to get pieces actually clean which eats into my bottom dollar. Is there a quick and inexpensive way to get the oil off? I was thinking of building a narrow vat to keep solvent in or something to eat the oil off.
Just a note about brake cleaner! Unless restrictions have removed them from the market, there are some brake cleaners refereed to as chlorinated that can be dangerous when mixed with mig or tig welding because of the combination of heat and the inert gas of argon. The result is phosgene gas which is notable from WWI. Very nasty stuff to say the least!
Scott
That's good to know Scott!
abmetal
Post by abmetal »
I NEVER use brake cleaner. I know there are 2 different kinds of which only one is dangerous but after reading an article about a gearhead that almost died from using it, I stay away from it. His health was permanently affected.
Allen
K D Metalwerks
Post by K D Metalwerks »
I have good luck with acetone. Just a splash on a fiber rag does the trick. It dissipates quickly and leaves no residue.
K D Metal Werks
PlasmaCam DHC2
Hypertherm Power Max 45
Hobart Handler 190 Mig
Niagara 3"x 36" Slip Roll 14ga
Driess/ Krumph 4' box & pan brake 16ga
Hossfeld #2 Bender Ridgid 700 threader
Pexto 137-1 16ga. Stomp Shear
MADE IN USA
K D Metalwerks
K D Metal Werks
PlasmaCam DHC2
MADE IN USA
