Trump eagle
- cstroke
Trump eagle
Thought this was funny when I saw it so I did a quick drawing and cut it out.
Hopefully someone can use it.
So here I am many years on this forum and i still cant post images... Yep I cant figure it out.
Here's a link to the picture.
If not to much trouble can someone tell me how to directly post a picture from imgur to here???
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
- lockeyone
Re: Trump eagle
I just went to your image, clicked on view image, right clicked to save image to my desktop. Then opened full editor, scrolled down to the attachments tab, click on add files, found file and clicked on it. It should be listed below text box and you can add a file comment if you wish.
Table 4'x4', BladeRunner EtherCut 620 LINUX w/CommandCNC
Hypertherm 65 CPC/RS485 Machine torch 2016
BobCad router 50"x50" MACH3 2kw spindle 2003
Shoptask Eldorado cnc MACH3, 1999
Epilog Mini 24 60watt, 2013
Vectric Aspire CoralDraw x6 SheetCam
Re: Trump eagle
You use the same procedure you used for posting the DXF file only select a jpeg (image file). use the preview to check how it will look before posting if you like then submit. If you add many they are stacked first is at the bottom of the list, I use the click on each one to put them in order and than hit enter to place the next on the next line below. You can play with it to check just don't submit if you testing the procedure out.
- otisa2007
Re: Trump eagle
thats awesome thanks for the share
- cstroke
Re: Trump eagle
Ugghhhh I really cant figure out for the life of me why I was having so much trouble.
At one time on this board didnt we have to have a remote file location to post pictures?
Thanks for the help guys.
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
- ben de lappe
Re: Trump eagle
You must be referring to the Project Picture Gallery, located on the Board index a few topics down.
- ETCWeld
Re: Trump eagle
i like it! thanks
Re: Trump eagle
Cut perfectly!
Re: Trump eagle
Very Nicely Done!!
Re: Trump eagle
This is awesome! Thanks for posting this one
- Larry83301
Re: Trump eagle
Here you go!!!cstroke wrote: ↑Sat Jun 20, 2020 6:00 pm Thought this was funny when I saw it so I did a quick drawing and cut it out.
trump eagle 20tall.dxf
Go down below the Quick Reply and click on "Full Editor and Preview" After you get there you will see "two tabs under the large text box, the are "Options" and "Attachments" Click the attachments tab, that will take you to another tab that says "Add files" click that. You then have a typical add files box like most online sites have for you to select the place to find your file and add it to the file name bar in the lower line. When you have selected your file click "OPEN" and you will come back to your posting, if thee file type is one of the type that can be posted and the file size is not to large it will be loaded to a staging line. Then all you need to do is select a spot in your post where you want to place the file,( I make a new line at that point by hitting RETURN) click there and then move your pointer down to the line where your file is listed and click "Place inline". At that point you can either add more things to your post or do one of the three options just below your post. I like to preview my posts but that's your choice. When you are done make sure you click on POST so the rest of us can see what you have.
If you haven't made a picture yet, or don't know how to get a picture of your file try these two different ways, both work OK.
1: In your CAD or whatever you use to make your files in, bring in the file that you want to make a picture of, center it and enlarge it so it fills most of your screen. After you have the part you want to make a picture of just right look on your keyboard (top row of keys) and find the "Prt Scr) key, push it, then open "PAINT" or something like it and find the "paste" tab. You will then have a copy of your CAD screen with your project in it. Find the "select" tab and click and drag the box until you have the picture you want inside the box, click the mouse and the select box will stay just like that. Now go to the menu on top and click on crop and everything that was outside the box will go away. Now under the file tab you have the option of saving the picture to wherever you want to, be sure to save it as a JPG as the board likes that best (no BMP) Your done. When you post your CAD file you can post your picture file above or below it.
2: You can use "Snipping Tool" from Win 10 if you have it and save a bunch of steps. Just follow the part above to get your file on the screen and then open "Snipping Tool" click on "new" and you get the select box just like in "paint". Select the part of your screen you want (click and drag) and then release the mouse. A new box pops up with your picture in it. Under the file tab is save so you can tell it where to put the picture and what to call it. That's it, your done.
Hope you can figure out what I'm saying, tried to make it clear (not sure I did) hope this helps
Larrry
Re: Trump eagle
Awesome job! Thanks for sharing
