Hi
My pierce height & cut height in sheetcam 2mm. But in mach3 when the torche hit the métal ant goes up to 5mm . Thc goes up torche to almost 10 mm
I can't understand why the machine doesn't use cut height in shettcam 2 or 3mm
Knowing that the cut quality is great
Thanks in advance
Mach 3 & cut height
Re: Mach 3 & cut height
I suspect it may be because you are using a fake / well shared / blocked mach3 licence
https://www.machsupport.com/forum/index ... #msg245713
Mach3 has some bugs that have been added to it to do strange things when you run a pirated licence so that you never get it to cut right or finish a job.
But i have a good cut qualityrobertspark wrote: ↑Mon May 18, 2020 7:20 pm I suspect it may be because you are using a fake / well shared / blocked mach3 licence
Well you are still using a pirated Mach3 licence (most people would act surprised at this part, and consider buying a proper licence or ask what their options are).... good luck you obviously know what your problem is.Cryptoosam wrote: ↑Mon May 18, 2020 7:51 pmBut i have a good cut qualityrobertspark wrote: ↑Mon May 18, 2020 7:20 pm I suspect it may be because you are using a fake / well shared / blocked mach3 licence
Note: https://www.machsupport.com/software/mach3/
Without a license, Mach3 will operate in Demo mode.
While in Demo mode, the software has the following limitations:
Mill & Plasma: 500 line gcode limit (10,000,000 limit after licensing)
Turn: 50 line gcode limit (10,000,000 limit after licensing)
Kernel Frequency locked at 25kHz (only applicable if using the parallel port driver)
Set Next Line function disabled
Run From Here function disabled
Turn: Threading disabled
Plasma: THC functions disabled
