Need help converting a dxf
rsansing
Post by rsansing »
I need help converting a dxf file. I have access to an Esab machine at work and when I try to load the file I get an error. I have no experience with cnc machines and would like to make this metal art for my wife. Is there a way to get this file converted to something my machine will read without spending hundreds on software I will never use?
Re: Need help converting a dxf
It needs to be converted to a .tap (G-code) for many of the CNC systems. Very easy to do but there can be a differences in the the table electronics.
If you can ask what Post processor is used at work, and what thickness you are cutting will help.
ou812
Post by ou812 »
will this help
Here is the original cleaned up with crossovers removed.
moonandback 18x18 dxf export.zip
ou812 wrote: Tue May 19, 2020 8:12 amwill this help
Nice work ou812! This one looks good, but still has a few problems with crossover and open path.
Here it is after cleanup.
Moon dxf.zip
