SheetCamRemote.dll - Defective Plugin found
Self-MadeFabWerx
Post by Self-MadeFabWerx »
When I open mach 3 this error pops up.
If I remove the plug in from the mach 3 plugin folder it will open fine with no errors.
I have searched google for over an hour and can not find anywhere to download this plugin at.
Does anyone know where I can download this plug in from?
robertspark
Re: SheetCamRemote.dll - Defective Plugin found
Post by robertspark »
Do you use sheetcam?
Self-MadeFabWerx
yes sir.
robertspark
Delete the DLL and reinstall sheetcam (Dave your tools first) and it should detect mach3 and install the mach3 DLL plugin.
Then go into sheetcam and go to option / plugins and enable the mach3 plugin in sheetcam.
You will then need to start mach3 and go to plugins there too and enable the sheetcam plugin
Restart mach3 and everything should work just fine with sheetcam being linked to mach3
(I'll do some screenshots later for you)
Self-MadeFabWerx
thank you
Return to “Mach3 & Mach4 CNC”
