Cutmaster 101 CNC Board
Hi everyone, first post. If this isn't the appropriate place for it please let me know. I just got a killer deal on a cutmaster 101 and I'm in the process of building a CNC table. I was hoping maybe someone would have a lead on a CNC interface card so I can run the sl100 sv torch. Or is it possible to make the sv torch work without the interface card? Thanks in advance!!
Re: Cutmaster 101 CNC Board
Welcome. No problem making that work without the interface card, just need to hook up your 2 trigger wires, and 2 wires for THC if you decide to use a THC on your machine. Without the interface card you will use raw voltage for a THC rather than divided voltage.
By far the cheapest option to deal with raw arc voltage would be a $69 Mesa THCAD-300 plus a Mesa 7i96 ($119) or Mesa 7i76e ($199) which will allow you to build a high performance plasma table using Linuxcnc and its plasmac configuration.
http://linuxcnc.org/docs/devel/html/pla ... guide.html
