TM2- Howdo you incease the jog speed
I have the TM2 table and software and I would like to know how to increase the jog speed, thanks
Re: TM2- Howdo you incease the jog speed
I'm not a TM user but I suspect it will be in your post processor under rapid speed or similar term. Shouldn't be tough to locate and change. Good luck
- ben de lappe
Prior TM 3 finished machine user with TM 4 driver software. No knowledge whatsoever of TM 2 but as the software is proprietary possibly in your driver software settings, see pic. Probably not as obvious as my Jog Speed button, total shot in the dark till someone with 2 experience chimes in. May also help to list your AVHC if applicable as well as driver for motors. Mine was model 401A signal generator.
Right here
