Drawing Import issue - Missing profiles, missing lines
Symfab
Post by Symfab »
I am having an issue importing a DXF into Sheetcam. it is a simple file. When I upload the drawing the lower notch in the fins is missing. Any suggestions? I have attached the file and a picture of the screen. Thank you very much!
RCwallfins1-5v2.dxf
(181.43 KiB) Downloaded 62 times
Les Newell
Re: Drawing Import issue
Post by Les Newell »
What cad package did you draw them with? The outlines are splines rather than lines and they appear to be triggering an obscure bug in SheetCam.
As a workaround load the drawing back into qcad, select everything then select Modify->explode. The drawing should now work.
Symfab
Post by Symfab »
That did the trick! thank you very much!
Return to “SheetCam”
