I have this older CANDCNC Blade Runner II G251-4 Series E complete setup, I used it with a Powermax 45 years ago. I want to now dust it off and build a cnc router table. Since the electronics will be used for routing now, I am sure there are many functions plasma needed that wont be necessary for the router.
My questions-
Is it possible to somehow adapt an Ethernet connection? If so, how?
If it is impossible to adapt, are there any parts I can take off of this system to use with a low cost future pieced together setup?
Re: CANDCNC Blade Runner II G251-4 Series E
All our controllers will do router . Its simply a change in the MACH3 Profile that takes the THC settings off the screen and changes the m3/m5 trigger to output 2 (realy on the tableI/O board) as far as using parts the G251 drivers are still being made and still being used. The UBOB card is a general parallel port BoB but it needs satellite cards (Table I/O and MTA to interface .
You can get more direct help on the CandCNC Support Forum Free to join. Open to anybody interest in CNC router or plasma cutting
It will operate as a single port BoB . 5 inputs (4 usable ) 4 axis of control. The UBOB has an input doubler (port expander) that only works with a connection to a parallel port and running a MACH plugin ...The ESS has a different driver. Later UBOBs after REV 12 had an extra header to use with the 2nd port on the ESS to gain back the lost inputs
Great (I hope).tcaudle wrote: ↑Tue Apr 16, 2019 4:31 pm It will operate as a single port BoB . 5 inputs (4 usable ) 4 axis of control. The UBOB has an input doubler (port expander) that only works with a connection to a parallel port and running a MACH plugin ...The ESS has a different driver. Later UBOBs after REV 12 had an extra header to use with the 2nd port on the ESS to gain back the lost inputs
Please take a look at these images below. One pic of the back & one of the front of my unit. I could only find a graphic of a UBOBIII REV5, I have a UBOBIII REV1.
If possible, can you tell me the connections that need to be made?
ESS Port 1 to_____________________
ESS Port 2 to_____________________
ESS Input 5V (+) to_________________
ESS Input 5V (-) to_________________
If you recommend a standalone External 5V power supply to power the ESS, I can do that also.
