I am getting an error message when I load a G-code into Mach 3 that is bugging the heck out of me. This happens when I run a Plasma mode Mach 3 profile and I load any G-code in it will stop and give then message "Radius to end of arc differs from radius to start" and go no farther in the initial reading of the G-code. If I load another profile it will work just fine. It is not related to the G-code as I have tried many G-codes all work in on profile and none in the other. I am sure it is a setting in Mach.
Help would be appreciated
Error message question
Re: Error message question
I went to the Mach3 form and found the answer, change the IJ mode to Inc from Absolute works fine now
- ben de lappe
You never cease to amaze me acourtjester. Thanks for all you do.
Thanks you sir It's in my blood
- SeanP
Don't know how we would manage without the internet! well done.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
