Why doesn't my button script work?
djreiswig
Post by djreiswig »
I have the attached button script I want to use for referencing my Z. I have a button on my screen to switch between using my z switch and my ohmic for referencing. I have created a reference macro to use in sheetcam that looks at an LED that is turned on and off by the button and uses it to determine if it should reference using the switch or the ohmic.
The macro code is just a duplicate of what my post processor used to put in the gcode. Now it just calls the macro instead. It seems to work fine when I run it from gcode, but I wanted to make the Z REF button work similarly. I tried just calling the macro from the button, but I couldn't get it to work. It just kept giving me an error, so I attempted to duplicate the macro code in a button script. I had to make a couple of changes, but I think I have it figured out.
The G31 using the probe input works fine. The G28.1 with the switch seems to raise up a little more each time I click the button. It drops and touches, then over runs into the switch, then it backs up. The first time it stops on TOM, the next time it raises above the material. Each time I run it, it ends up higher. Something seems to be adding a little distance each time.
It won't work correctly again until I restart Mach. Then it goes back to TOM. It will work correctly if I step through the code from the button script editor. That's what has me confused.
The -.25 raise is used along with a block delete arrangement I have where I can turn on block delete and it ignores the torch firing and DTHC on settings and raises the torch .25 above the material and does a dry run. I commented that part out and it didn't make a difference.
I have attached the script. Any ideas on what might be wrong, or a better way to do this?
refscript.pdf
(58.26 KiB) Downloaded 89 times
Re: Why doesn't my button script work?
I do think the button script is in a different code language then G-code so a direct copy will not work.
attached is a button script I used to reposition the torch from a laser position
I needed to put the word code before the command and use parentheses at both ends which changes the code to red lettering.
I cannot write script just rearranged what another script did to work for me. :lol:
djreiswig
Post by djreiswig »
Yes, scripts are in Cyprus Basic. Very much like Basic code. I'm baffled why it seems to work when I step through it. I thought maybe it was a timing thing so I added lots of Sleep lines, but it made no difference.
I'm sure someone here will have your answer
robertspark
Post by robertspark »
In the last few lines, why do you set g92 z0 and the move the axis up only to then reset g92 to the offset height again.
On your motion controller do you have a spare relay?
I ask because what I do with mine is I use g31 and then test if it is the ohmic or the floating input that is triggered and then set the offset accordingly.
You basically feed the omic probe input via a relay and the floating head input direct to the probe input. So that whichever is triggered will trigger the probe input ... Then you test and set accordingly all via macro.
I also have a similar bit of code to test for if the probe is active at the start of the probe and if the ohmic is already active I can drop the relay out, retest and the just use the floating head input
djreiswig
Post by djreiswig »
The reset is for if I am in block delete mode. If I'm not then I reset the z back to 0. Otherwise it stays at -0.25 so it will float higher above the material. My first thought was to use the same input and use a relay, but I thought I could save the hassle and just do it with code. I just can't figure out why it works fine when I step it, but not when I hit play or use the button.
robertspark
I'm going through the code now (1st time in front of a laptop)
You have 1 syntax error on line 35
code "M00"
should be Code ("M00")
And another on line 8
code ("M00")
Why are you using block delete for switch offset???
robertspark
It may be me here...
But where did you define DIGITIZE + ZHOME
DIGITIZE is OEMLED 825
Z HOME is OEMLED 836
The below code "MAY" work better......
Code: Select all
OhmicLED = 1503 ' LED that indicates OFF
TouchLED = 1504 ' LED that indicates ON
RefTypeRelay = 17 ' Output 8
If GetUserLED(OhmicLED) Then 'ohmic sensor touch off
	If GetOEMLED(825) Then 'Probe Input (Digitize) Active
		Response = MsgBox ("Ohmic sensor jammed. Clear and hit RUN to continue ", 4 ,
		"Clear Z Jam")
		Code("M0 (Program Stop)")
	Else
		ActivateSignal(RefTypeRelay) 'Turn on Ohmic
		Sleep(200) 'allow relay time to toggle
		Code("G00 Z" & GetUserDRO(1101) & " (Start probe touch-off)")
		While (IsMoving())
			'Sleep, so other threads can run while we’re waiting
			Sleep(100)
		Wend
		Code("G31 Z-3.937 F" & GetUserDRO(1100))
		While (IsMoving())
			Sleep(100)
		Wend
		If GetOEMLED(66) Then 'trial Z offset
			Code("G92 Z-0.25 (Trial Z offset)")
		Else 'not trial Z offset
			Code("G92 Z0.0")
		End If
		DeActivateSignal(RefTypeRelay) 'Turn OFF Ohmic
	End If
Else
	If GetUserLED(TouchLED) Then 'floating head touch off
		If GetOEMLED(836) Then 'Z Home Active
			Response = MsgBox ("Touch switch jammed. Clear and hit RUN to continue ", 4, "Clear Z Jam")
	Else
		SwitchOffset = GetUserDRO(1045) 'switch offset
		DeActivateSignal(RefTypeRelay) 'Turn on Touch
		Code("G28.1 Z" & GetUserDRO(1101) & " (Start touch-off)")
		While (IsMoving())
			Sleep(100)
		Wend
		Code("G92 Z-" & SwitchOffset & " (Switch offset lift)")
			Code("G92 Z0.0")
		End If
	End If
End If
This bit of your code did not make sense to me at all.....
Code: Select all
Code("G92 Z0.0")
 Code("G00 Z" & SwitchOffset & " (Switch offset lift)")
 While (IsMoving())
 Sleep(100)
Wend
 Code("G92 Z -0.25 (Trial Z offset)")
 While (IsMoving()) 'Sleep, so other threads can run while we’re waiting
 Sleep(100)
 Wend
 If Not GetOEMLED(66) Then 'not trial Z offset
 Code("G92 Z0.0")
First you zero'd the Z axis with G92 temporary offset
Then you told the machine to rapid move to switch offset
Then you told the machine to reset the temporary offset to Z-0.25.... (why)
but if block delete was NOT active.... set G92 Z to ZERO???
Have a look at my alternative code it may help you out....
NOTE: I am no longer a Mach3 user.... so my coding may be rusty (a little)... but as the responses seem slow I thought I'd try to help.
These are the Mach3 manuals I use to use:
http://www.machsupport.com/wp-content/u ... mmands.pdf
https://www.machsupport.com/wp-content/ ... og_Ref.pdf
https://www.machsupport.com/forum/index ... tach=27839
robertspark
Edited the code in previous post....
added in DeActivateSignal(RefTypeRelay) 'Turn OFF Ohmic
At the end of the 1st section
djreiswig
Post by djreiswig »
I think I figured it out. I was editing it from within mach, and for some reason it wasn't saving it. I used the screen editor and now it stays how I have it. I also added a couple of extra sleep loops after the G92 lines. It seems to be working as intended now.
To answer your questions...The parenthesis don't seem to be required, but I did add them back in. ZHOME and DIGITIZE are Mach output constants. You can use them like OUTPUT1, OUTPUT2, etc.
The last part of the code raises the Z an extra .25" if I have block delete active. I changed that around a little too. I originally had it in my post processor and that was the only way I could seem to get it to work. I got rid of the NOT and the double zeroing. I changed the DRO numbers as I must have had one that was already used somewhere because it wouldn't keep its value.
Code: Select all
RefFeed = 1120 ' Ref Feed from Settings
PlungeSafety = 1121 ' Plunge Safety from Settings
TrialZ = 1122 ' Trial Z from Settings
RefTypeRelay =17 ' Output 8
SwitchOfset = 1045 ' Switch Offset from Settings
  If IsActive(DIGITIZE) Then
    Response =  MsgBox ("Ohmic sensor jammed.  Clear and hit RUN to continue ", 4 , "Clear Z Jam")
    code ("M00")
  Else
    Code("G00 Z" & GetUserDRO(PlungeSafety) & " (Start probe touch-off)")
    While (IsMoving())
      Sleep(100)
    Wend
    Code("G31 Z -3.937 F" & GetUserDRO(RefFeed))
    While (IsMoving())
      Sleep(100)
    Wend
    Code("G92 Z0.0")
      Sleep(100)
    Wend
      Code("G92 Z -" & GetUserDRO(TrialZ) & " (Trial Z offset)")
        Sleep(100)
      Wend
      Code ("G00 Z 0.0")
    End If
  End If
Else
  If GetUserLED(TouchLED) Then 'touch
    If IsActive(ZHOME) Then
      Response =  MsgBox ("Touch switch jammed.  Clear and hit RUN to continue ", 4 , "Clear Z Jam")
      code "M00"
    Else
      Code("G28.1 Z" & GetUserDRO(PlungeSafety) & " (Start touch-off)")
      While (IsMoving())
        Sleep(100)
      Wend
      Code("G92 Z0.0")
        Sleep(100)
      Wend
      Code("G00 Z" & GetUserDRO(SwitchOffset) & " F" & GetUserDRO(RefFeed) & " (Switch offset lift)")
      While (IsMoving())
        Sleep(100)
      Wend
      Code("G92 Z0.0")
        Sleep(100)
      Wend
          Sleep(100)
        Wend
        Code ("G00 Z 0.0")
      End If
    End If
  End If
End If
djreiswig
Post by djreiswig »
I appreciate your help. Its frustrating when you don't get any response. I was thinking my explanation wasn't clear.
I did add your last suggestion.
Code: Select all
robertspark
Documentation for mach3 has always been very poor.... No chance to fix it now though.....
It's sad that it was never finished off / developed further because it has such a following.
Cypress visual was so easy / logical....
Now using c# (uccnc) which is ok but syntax errors can be such a pain in the rear.
djreiswig
Post by djreiswig »
I've done a little Arduino programming, which I believe is basically c#. It's pretty strange compared to the BASIC I'm used to.
Return to “Mach3 & Mach4 CNC”
