Duck Hunter Welcome Sign
I'm needing a dxf file of this sign does anyone out there have this file thank you in advance
Re: Needing dxf file
Try This
- Cz_apie
Thanks for sharing, nice clean file
Deon
Deon
Plasmacam 4x4 DHC2 Table
Design Edge 4.36 Advanced Design
Advanced Height Control
Hypertherm PM 65
Mac Afric Cut 40 Plasma
Mac Afric Mig 195
Mac Afric Tig 200A
Thermax DC 200
Fulgor Butt Welder
13" Metal Lathe-Milling Machine
Rong Fu 25 Mill
Hypertherm PM 65
Mac Afric Mig 195
Mac Afric Tig 200A
Thermax DC 200
Fulgor Butt Welder
Rong Fu 25 Mill
Thanks for the dxf file on this. I like the font on welcome!!
- david jordan
Re: Duck Hunter Welcome Sign
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
- hdfaster
Thank you!
Thanks for the file!
Nice file! Here it is scaled to inches from metric.
Im trying to download this file as I have a custoemr that wants this cut. When I try to open in inkscape it gives me the following error:
30 entities of type polyline encountered and ignored. Please try to convert to release 13 format using qcad.
What the heck does that mean and can someone tell me how to do it?
- ROKCRLER
Rick,
Try these
I opened them it in QCad and saved as DXF14 and SVG.
Opened in Inkscape and ungrouped, selected all the internal pieces and combined, then selected the outside and differenced. Make sure the outside graphic is at the bottom of the stack.
Try these
4x8 Dynatorch
PM85
~Mo~
PM85
~Mo~
You are using an older Inkscape version which did not allow import of DXF R14 file format. I would recommend downloading and installing the latest Inkscape version 1.2.2 which will directly open/import DXF R14 files.Rickzink wrote: ↑Tue Jul 18, 2023 4:47 pm Im trying to download this file as I have a custoemr that wants this cut. When I try to open in inkscape it gives me the following error:
