New here, if this has already been discussed please direct me to the conversation. I have a 12 year old torch mate...
After creating dxf files to cut, the torch cuts great, literally everything is perfect, except between each cut, the torch re-pierces the metal wherever the cut finished. For example, If I was cutting out 3 circles, the torch would cut out the circle, rise to starting position and drop to re-pierce the ending point and then begin the second Circle. It will do this between each cut. I usually use online toolpath for everything, could this be the reason? Any other reasons why it would do this?
Torch reporting after each cut- help!
Re: Torch reporting after each cut- help!
Sounds like the post prossesor issue.. should be able to see the issue if you scroll through the gcode.
