Does anybody know where to get replacement "O" rings for the T45m torch.
I haven't seen any listed on the hypertherm site.
T45m torch
Re: T45m torch
Call the tech line, I think I found the one for my torch in the manual showing parts break down, also buy the silicone lube for the O ring. It just needs a small amount but helps alot.
Re: T45m torch
Here is the parts breakdown (copied from the service manual...this is also in the operators manual). The Oring is part number 058503 from Hypertherm, the generic info is: Oring, Viton, .625 x .070" (for sourcing locally). Jim Colt Hypertherm As always.....the service department or customer service at Hypertherm can help with Hypertherm questions! Contact info for both is in your operators manual near the front!
Re: T45m torch
Awesome, thank you.
Went to the welding supply store they let me take one off one of their machines.
went home and put it on. Wah! Lah! problem solved.
Such a simple thing that causes so much grief.
I ordered a bunch of them so I have extras.
