I'm hoping someone will have some ideas for me to try. I'm working on a sign with a name & wedding year inside of an oval frame. It's drawn in Rhino 3D, which I don't know if anyone else on here uses; it's along the same lines as AutoCAD, SolidWorks, etc. I have to export it as a dxf to import it into Sheetcam (Rhino doesn't do svg's). I've played with the export settings and tried earlier dxf versions, and get one of two things: 1) the outer oval is distorted or 2) any of the curves end up faceted instead of smooth. I attached picture of what it looks like in Rhino, along with what I'm seeing in Sheetcam, as well as the dxf files. I don't seem to have any issues with circles, other curves, or straight lines. Is there something unique about the geometry of an oval that could be giving me problems? I even tried drawing a couple of other ovals in another file, and I get the same issues.
Thanks for any thoughts you might have.
Tim
Ovals that aren't ovals
- Attachments
- Groneman nameplate - Copy.dxf
- (172.38 KiB) Downloaded 40 times
- Groneman nameplate.dxf
- (511.44 KiB) Downloaded 49 times
Tim Eggleston
Banks High School
Banks, OR
Arc Pro 4800
PowerMax 45XP
Mach 3, SheetCam
Inkscape, Rhino 3D
Banks High School
Banks, OR
Arc Pro 4800
PowerMax 45XP
Mach 3, SheetCam
Inkscape, Rhino 3D
Re: Ovals that aren't ovals
I would switch from Rhino to Inkscape projects like that are very easy to construct as you can convert normal fonts to paths. It will do all kinds of shape following with the letters, it welds letter to lines. And it saves in SVG or DXF file formats, FREE for download too a large number of tutorials on the web too..
- East German
Hello Tim
I do not know the program. I opened it with VCarve and saved it then it works.
I hope this help!?
Peter
I hope this help!?
Peter
- Attachments
- Groneman nameplate Vectric.dxf
- (105.91 KiB) Downloaded 43 times
MyPlasmCNC
Hypertherm Powermax 85
Machine Torch
Hypertherm Powermax 1100
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
I'm with Tom on this one.
I use a combination of Inkscape, Qcad and then go to Sheetcam for a lot of my processes.
An ellipse is considered a spline in many CNC cutting machines, they just don't care for them... They won't polyline in ACAD at all so I don't use them in ANY design....period. Draw your stuff using 3 point arcs and practice blending the start stop points to give a smooth transition Works for me....
Thanks for the input guys. I'll try playing with arcs in the future to see if we can make that work.
I do have, and can use Inkscape, but to be honest I don't like it near as much as a good CAD program, and since I offer college credit through our local community college for Rhino I need to stick with that as much as I can.
Thanks for the help.
Tim
Tim
Tim Eggleston
Banks High School
Banks, OR
Arc Pro 4800
PowerMax 45XP
Mach 3, SheetCam
Inkscape, Rhino 3D
Banks High School
Banks, OR
Arc Pro 4800
PowerMax 45XP
Mach 3, SheetCam
Inkscape, Rhino 3D
Qcad draws eclipse with no trouble and my CNC plas will cut, with no issues.
- MemFor
Some reading into splines vs polylines might give you some insight. I recently learnt all programs do not interpret curves the same way.
This link might help: https://discourse.mcneel.com/t/save-as- ... ns/21505/7
