Im not one for requesting help. Typically I spend countless hours trying to make it work. With this image I provided, its pretty basic but due to the quality of the image, my basic PCAM is not producing "clean" looking letters.
Any assistance with this is greatly appreciated. I figured I would throw it out there and see what happens.
As stated above, Im running DesignEdge on my PCam 4x4.
If any additional information is needed, please let me know. The end result will be a simple rectangular sign similar to what is shown. I can handle adding additional segments to avoid drop outs on the letters.
Sam
ASSISTANCE WITH A CLEANING UP SIGN
Re: ASSISTANCE WITH A CLEANING UP SIGN
Here's my try. Included in zip folder is svg, bmp and dxf. Still needs work on a couple letters, but maybe my trace will save you some work?
- rdj357
Here's a DXF.
I used Paint.Net to increase DPI to 150 then enlarged to 12" or so. Then selected the background and erased it, painted the foreground black. Imported into Design Edge and smoothed to take the little bit of roughness from pixelation away.
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
Thanks for the help. That should do the trick. Ill have to check that out Robert.
