I have a Hypertherm 1250 G3 and I would say it is flawless. Works well. It can cut 1/2" all day and hardly ever start the cooling fan.
Good supplier of consumables is close by, and the LWS carries them as well.
ADDED BY ADMINISTRATOR
Visit the Webpage at Hypertherm about this model:
http://hypertherm.com/en/Products_and_S ... ax1250.jsp
Download Brochure about Hypertherm 1250 in mechanized applications (includes cut speed chart):
http://hypertherm.com/library/files/Pro ... 860270.pdf
Download System Brochure on Hypertherm 1250 plasma cutter:
http://hypertherm.com/library/files/Pro ... 860110.pdf
Hypertherm plasma cutter user experience
Reason: Hypertherm 1250 Manufacturers Website Link Added
Re: HYPERTHERM Plasma Cutters - Plasma Cutting Torches
I have been using a Powermax 1000 on my Dynatorch table for a year now with no problems . I like the CNC
ready arc voltage and control interfaces built into it. I have had a Powermax 380 for years that I use to cut up
my leftover steel skeletons on the table after cutting. I feel you cannot go wrong with Hypertherm equipment.
Their website also has a wealth of information and videos. They recommend straight lead ins on circle cuts,
rather than the circular lead ins. I tried it and I must admit, I get real clean cuts on inside circle cuts now.
For more information on this Hypertherm model visit this link;
http://hypertherm.com/en/Products_and_S ... ax1000.jsp
Reason: Hypertherm 1000 Manufacturers Website Link Added
I Use a HT4000 at work 100-200 amp 2 torches with a 144" x 600" table cuts .050 up to 3" if i push it..
The machine is a dream to run..
I have a Hypertherm 1250 on my Samson table. I use Plasma cam for my cutting software. Everything has run flawless for me! I just finished a job cutiing 1/4" perf plate and the machine worked great. I am very happy with my machine!
- Loyd
I have a Hypertherm 1250 and 380 I could not ask for a better machine. I love the finecut consumables .
The tech service is great. The sales rep in my area has been to my shop to help with any question I might have.
Jim Colt the Hypertherm rep that is a member of this forum is fantastic. I will always buy Hypertherm.
Loyd
Loyd
Hypertherm HPR260, this machine is awsome I never had an issue with performance, it is rated to cut 2 1/2" and I was able to do a 3" cut before. Couldn't ask for a better machine
- ou812
Our Titan II gantry system features multiple processes that yield superior part quality affordably. This machine supports beveling in plasma and oxyfuel, including the Rotator Delta Plasma Bevel. Available in widths from 8' to 14' and lengths from 6' to 100'.
we have this 1 setup at 10'6x29'6
it has hypertherm hy speed HT 2000 on it
it goes from 40 amp up to 200 amp
it will cut 1'' at 50'' a min
does art work to but files have to be very good
i use flexisign pro and fastcad and autocad
and pronest10
hypertherm HT2000
Delivers fastest cut speeds and lowest operating costs available for 200-amp oxygen plasma
Production cutting capacity (piercing) - mild steel 25 mm (1")
Maximum pierce capacity - mild steel 38 mm (1 1/2")
Maximum cutting capapcity (edge start) - mild steel 50 mm (2")
and pronest10
hypertherm HT2000
- Attachments
- IMG_1088.jpg (49.98 KiB) Viewed 2134 times
