post issue
kbenz
post issue
Post by kbenz »
I had to install sheetcam on a new computer. I used the post processor per Luke at CandCNC. torch comes down, touches the ohmic sensor, goes up .150 then goes another .250" roughly, then pierces, lowers some (but not to the specified cut height) and cuts. on holes it never lowers to the cut height at all (.375" hole) switch offset is 0 in sheetcam and .060 in mach
CandCNC
Mach3
Draftsight
Hypertherm 65 machine torch
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
sphurley
Re: post issue
Post by sphurley »
What does the G-code show?
Platform CNC Plasma table
CandCNC Ethercut IV DTHC
Hypertherm 85/CPC/RS485
Miller 350P
Miller Dynasty 280DX
Re: post issue
I have had the problem check this location when selecting the post processor, first load the processor and exit to the main screen in sheetcam and then go back to the post processor. You will see the box with "set custom post options" click on it then in the switch offset box put a value of 0.001 and click OK. that will fix that for you. if it has 0.00 it will offset the 0.250"
switch offset.jpg (57.62 KiB) Viewed 1017 times
kbenz
Re: post issue
Post by kbenz »
Thanks. What is the".75" in ref distance for?
CandCNC
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Les Newell
Re: post issue
Post by Les Newell »
If you have two cuts close together the post won't bother to reference the torch between the cuts. Refdistance controls the maximum distance for this. Note the distance is the total cut + rapid move distance.
kbenz
Re: post issue
Post by kbenz »
acourtjester wrote:I have had the problem check this location when selecting the post processor, first load the processor and exit to the main screen in sheetcam and then go back to the post processor. You will see the box with "set custom post options" click on it then in the switch offset box put a value of 0.001 and click OK. that will fix that for you. if it has 0.00 it will offset the 0.250"
Nailed it. Thank you sir :)
CandCNC
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Re: post issue
Happy to help :)
Return to “SheetCam”
