K just want to clear up something I heard about ohmic sensing, I heard that after the torch fires that it also senses tip voltage to help the DHTC run right????
I was under the understanding that Ohmic was only used to find the top of the plate for the right pierce height instead of using a limit switch???
Railmen
Ohmic sensing
Re: Ohmic sensing
The ohmic has nothing to do with arc voltage. Arc voltage is what voltage it takes to maintain a height based on the current (amps), consumables, speed of movement and material to a lessor degree.
You are correct in it is just to find the top of material without pushing down and distorting thin gauge.
Platform CNC Plasma table
CandCNC Ethercut IV DTHC
Hypertherm 85/CPC/RS485
Miller 350P
Miller Dynasty 280DX
Miller 350P
