Has anyone tried one of these for a plate maker?
Curious how well it works considering the down pressure from the air cylinder may work against the scribe hammer.
I am in process of adding plate maker to my bladerunner table.
Thanks in advance for any info.
RL
Pneumatic Air Scribe Hammer
Precision Plasma
5 * 10
CandCNC ETHERCUT
Bladerunner Stepper
Hypotherm 65
5 * 10
CandCNC ETHERCUT
Bladerunner Stepper
Hypotherm 65
Re: Pneumatic Air Scribe Hammer
I have one and I run the air cylinder down pressure as about 5 PSI I use 2 regulators one for scribe and the other for down cylinder.
I will order one and install, once I figure out how make / mount cylinder slide.
thanks for the reply. I assume your hammer scribe works well.
RL
RL
Precision Plasma
5 * 10
CandCNC ETHERCUT
Bladerunner Stepper
Hypotherm 65
5 * 10
CandCNC ETHERCUT
Bladerunner Stepper
Hypotherm 65
I have not used it very much but works great
Looks great!
Thanks!!!
Thanks!!!
Precision Plasma
5 * 10
CandCNC ETHERCUT
Bladerunner Stepper
Hypotherm 65
5 * 10
CandCNC ETHERCUT
Bladerunner Stepper
Hypotherm 65
What settings have you played with so the engraver doesn't dig in at the beginning and end of the cut? I've got the regulator turned down about as low as it'll go, cylinder won't extend if I lower it much more, and have set the delay time to 0 and yet it still digs in at the beginning and end.
Have you done any marking on painted surfaces? To give more contrast we cut the part out, painted it, and went back to engrave it, doesn't look terrible but I thought it'd come out cleaner
can u engrave a part then go back an cut it out ,,do u have to offset for the engraveracourtjester wrote:I have one and I run the air cylinder down pressure as about 5 PSI I use 2 regulators one for scribe and the other for down cylinder.
- tnbndr
Yes, if your scribe is mounted to the side of the torch mount. I do all my scribing first then plasma cut. Scribe set up as a tool in SheetCam and yes you have to put the offset in the SheetCam post processor. I did not do this it was done by the table builder, LDR, but I know it was done.can u engrave a part then go back an cut it out ,,do u have to offset for the engraver
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
You set that up in SheetCam you just use 2 tools one for plate marking using the layer or contour in the svg/dxf file. Then after all plate marking is done do the other layers using the plasma tool.can u engrave a part then go back an cut it out ,,do u have to offset for the engraver
acourtjester THANKS I AM TWO GETTING ONE SOON AN THANKS FOR THE INFO,
