simple clamp
simple clamp
I needed to hold a small piece of flat stock to the end of a tube so I could tig it on. Here is a simple clamp I made to do it. It is a scrape piece of angle with a threaded hole (3/8"-16) on one side. I used a "C" clamp to hold it to the tube and slid the flat stock in and tightened the 3/8" bolt :D
little blue choo
Re: simple clamp
Post by little blue choo »
That's using your head for something other than a hat rack. Good idea acourtjester.
Rick
Arclight 9600 4x8 table
Re: simple clamp
I believe in the “KISS’ principal, Keep It Simple Stupid :D :lol:
tnbndr
Re: simple clamp
Post by tnbndr »
Good idea. I have several of these laying around.
http://www.grainger.com/product/19C749? ... 10134709:s
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
Craig
Re: simple clamp
Post by Craig »
Good Idea. Craig
Craig Johnson
gamble
Re: simple clamp
Post by gamble »
Maybe it's just me but what about a magnet? Or holding it with 1 hand and tacking it?
Torchmate 2x2 - Flashcut
Powermax 45 - Machine torch
Taig CNC Mill - Flashcut
Razorweld Distributor
Gamelord
4.5 Star Member
4.5 Star Member
Re: simple clamp
Post by Gamelord »
Problem with magnets is that it effects the welding. Usually I just hold it and tack. This clamp idea is pretty good though, should save some heat on the fingers.
Torchmate CAD
