Curved/arched Text question.
I am curious if the Torchmate software is capable of curving/arching "only" the bottom of the text. I can do all the other text options, but this one has me stumped. here is an attached picture of what I am trying to do with the text. Thanks.
- Attachments
- text.png (12.06 KiB) Viewed 3012 times
Re: Curved/arched Text question.
If you cannot find how to do it you can use Inkscape by using the "envelope deformation" click on path then path effects and then the + sign and select envelope deformation. then select bottom bend path it puts a line below the text and take the cursor and move it up in the center. see attached.
- Capstone
Jester... thanks for the helpful tip!! One thing I noticed is that you must "convert object to path" a second time after you are happy with the shape otherwise the vectors will revert to the original object to path conversion shape in the background.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
Thanks Buddy. I really dont think the TM cad can do this. I could be wrong. Does correl Draw offer this feature aswell? Thanks for sharing the Inkscape way to do it!
I forgot to put that step in, I learned to do that when I do any changes, bummer to look at the nodes after a few steps and seeing them in the original position and having to back up.
RGR wrote: Does correl Draw offer this feature aswell?
Yep, CorelDraw has it too. I also use the Corel envelope tool to bring traces back into correct proportions when they have too much perspective in them.
Murray
Cool Ill go check out these envelope tools! Never really have needed it but its been one of those things I have been wondering about. Thank!
You can curve fit text with torchmate. When i click on transform, the first option is fit text to arc. I know a few years ago when I got my software I had to pay extra for this option. The education version came with all the features so I didn't have to pay for it when I upgraded software. Another way to curve text is to make the shape you like then click on your textbox icon. When you drag your pointer over the shape, the T changes colors.When it changes, this means it will fit text to the shape.
Josh Dahlem
Ag Teacher
Stanley FFA
Ag Teacher
Stanley FFA
go to 13:50 in this video, I have cad lite and this works on mine, this is where I learned. He has more videos that taught me a lot https://www.youtube.com/watch?v=AzWNlqKHTYI
- kchoghead
Curving text function was taken out of TM cad v9. you have to buy the add on text module to the tune of over 500 dollars to get the function now
That video helped me a lot!!
THANKS!
THANKS!
- SegoMan DeSigns
Doug Green has a how to channel for CorelDraw on YouTube.muzza wrote:RGR wrote: Does correl Draw offer this feature aswell?
Murray
