I have a customer who supplies 36" round plates and wants me to cut a design in each one.
Can someone explain how to put 0,0 to center of plate so I can set my torch up to start in center of plates? I am using corel 6 and am either blind or can't see the forest for the trees. I just have not figured it out. I tried moving the lines to create a cross hair but not get it to 0,0.
Thanks in advance,
Gary
Setting 0,0 to center of circle
Candcnc DHCTII Electronics
Sheetcam, Mach 3
Corel Draw 8, V Carve Pro
Miller CTS 280 Miller Mig
Sheetcam, Mach 3
- WyoGreen
Re: Setting 0,0 to center of circle
When you import it into Sheetcam, a drawing options box pops up asking where the drawing position will be. You can pick the center position there.
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
- Gamelord
- 4.5 Star Member
Not exactly sure what you are asking.....
If you are asking how to find the center of the circle, you can draw two lines perpendicular to each other and then use the centering feature in the alignment pull down to center the lines and the circle/oval, this will center everything together. You don't even need to get the lines perpendicular perfectly, just draw a vertical line, a horizontal line - both anywhere on the page, then select the two lines and the circle together, use the alignment tool to center everything horizontally and vertically and they will all line up automatically.
If you are wanting to move the center of the cirlce to the 0,0 position on your page in corel, you can do this by manually entering the x and y coordinates on the menu / icon bar on top of your page. Select the cirlce and next to the dimensions boxes are the placement boxes for x and y. Enter 0 for both and press enter and it will move your circle/oval directly to the 0,0 positon on the page.
If you want to put text or something else directly centerd in the circle/oval, you can use the alignement tools like listed above but use text instead of lines.
Hope that helps. If not then let me know.
Torchmate CAD
Torchmate CAD
Thanks for the reply's!
I need to start the torch in x0,y0 in center of plate as they supply round plate and I usually start from the corner.
Seeing as the circle is 36" diameter, I just wanted to cut the design in the center of the plate.
I think I have it figured out. I will let you know when I get a chance to cut these out this week.
thanks for the help.
Gary
Gary
Sheetcam, Mach 3
Sheetcam, Mach 3
The actual challenge is to locate the center of the bklank on the table. Doing a center origin and cut file is pretty easy. Aligning the torch and setting XY 0.0 is less so. Of every circle is very close I would build a jig with square edges and draw the jig onto the circle design and use it to define lower left 0,0
Short of that setup some sort of fence brackets that will set the circumference of the circle and give you a fixed offset from the table 0,0
If you have tomake more than 5 of something that needs custom positioning always consider a jig
- Gamelord
- 4.5 Star Member
If it is a perfect circle, just clamp two pieces of angle iron onto your table so that it forms an "L" shape. The corner of the "L" can then be set at 0,0. Then in Corel, draw a 36" box and place the cirle inside of the box, then center your cut-out to be in the center of the cirle. The box would be the sides of the angle iron clamped onto the table. Once everything is lined up and tool paths are made, zero your torch at the bottom corner of the angle, place your circle piece so that it is lined up against the angle iron and you should be able to cut. If you are doing multiple, this would make it very easy to do.
Torchmate CAD
Torchmate CAD
Thanks Tom and Gamelord,
I will try this out as there is possibly many more of these to do.
Gary
Gary
Sheetcam, Mach 3
Sheetcam, Mach 3
- SeanP
Don't forget to zero Y axis, unlike someone!
Luckily I got away with it.
https://goo.gl/photos/96d3WgyGqDskN8e99
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
