fine cut consumables
kcarpenter12
Post by kcarpenter12 »
i have a powermax 45 with hand torch on my table. I do a lot of 16. ga cs and smaller plate and want to know if I can get the fine cut consumables, or even use the 30A consumable package. thanks
Re: fine cut consumables
Post by jimcolt »
There are no Finecut consumables available for the Powermax45. If you open up your operators manual near the end of the mechanized cut charts you will find cut charts for the 30 amp shielded consumables as well as pictures and part numbers for the nozzle, retaining cap, electrode and swirl ring....you don't need the deflector. The parts are all different from the regular shielded consumables and will produce a cut that is similar to Finecut on other Hypertherm systems.
30amp consumables.png (48.36 KiB) Viewed 460 times
