Fathers Day - Dad's Garage Sign
- sewester
Re: PlasmaSpider DXF of the Week - Dad's Garage Sign
nice work thank you
Thank you:) Hope to use it sometime.
hello!! I am new to this CNC world, and I tried to nest this file on the program I received with my table, and it shows two signs,side by side, and says there are collisions !! Seems like every time I try to do a file like this , my program makes a big issuse of it!!!Like I said I am new at this!! Probably missing something!!! lol
It is an awsome sign!!! I hope I can figure it out some day!!!! Thanks Jason,fine work!!!
Bob
Bob
You will find that a lot of Jason's signs have two versions, the one on the left is usually the plasma cutting file deigned with open paths to cut at about the size it is, the one on the right provides looped paths to make it more suitable for laser or water jet which has a much smaller kerf or to be plasma cut much larger.
Murray
Murray
Thanks Murray!! How do i choose one or the other?? when i try to convert it i dont get a choice,that i know of!!! lol my Nessting program is IBE cnc cut, a German made program!!!
- Larry83301
Here you go. Didn't know which one you wanted so I attached both of them.bobrl wrote:Thanks Murray!! How do i choose one or the other?? when i try to convert it i dont get a choice,that i know of!!! lol my Nessting program is IBE cnc cut, a German made program!!!
Thanks Larry !!!
That's the great part about here, always plenty of help.
I usually bring them into Corel and just delete the one I don't need. I also do a bit of a check to make sure the ends of open paths are far enough away from other lines so as to avoid blow throughs.
Murray
Murray
This is how I used your drawing. I hope you don?t mind that I changed it for better suit my interest. The text says ?Magnus playhouse? and ?Repair shop? in Swedish.
Many thanks
/Magnus
Many thanks
/Magnus
- FreeDXF.com
Very cool modification of the design work. I like to see people use what I provide and customize it to fit their needs the best! Thanks for sharing. Awesome job! JH
- FreeDXF.com
I just gotta work on putting a Mustang in the middle and I plan on donating this to the local chicago based club for their season opener....Thanks a bunch, amazing sign!
Here's a few from some of your recent files so generously donated here Jason,jasonsmetaldesign wrote:Very cool modification of the design work. I like to see people use what I provide and customize it to fit their needs the best! Thanks for sharing. Awesome job! JH
Sean has an A tudor but fully fendered and running a late model Holden engine and hood top.
This was a birthday present for the guy who has everything including a custom '58 Biscane ordered by his wife, backlit with mica facing
Open faced and backlit
Another take on the 'one above with a '32 coupe and a more Aussie backdrop, again open faced and backlit
A raffle donation to the Renegades Hot Rod Club, painted silver marblizer over a black base.
thanks again
Murray
- ctorres3120
Thanks for sharing Jason
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
Hypertherm PowerMax 1250
http://www.facebook.com/ctorresp?ref=tn_tnmn
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
Re: Fathers Day - Dad's Garage Sign
Nice work Jason, thanks for sharing.
Very cool.
Thanks.
Thanks.
Best Regards,
Mike Volpone
MJV Graphics
CorelDraw X7
SolidWorks 2014
Coming soon: ShopSabre SideKick 8 w/ 6" Pipe Attachment
and HyperTherm 105
Mike Volpone
MJV Graphics
CorelDraw X7
SolidWorks 2014
and HyperTherm 105
- david jordan
Thank you, very nice.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Thanks Jason!
Awesome file! Thank you, Jason.
5 x 10 Air bladder water table
Precision plasma HDB gantry
CandCnC 620-4 Bladerunner
Feather touch ohmic plate sensing
Hypertherm Powermax 65
2015 Autocad lt
Mach 3
Central California
2015 Autocad lt
Mach 3
Central California
thank you for sharing Jason............. DJS in Texas
Fantastic file, thanks for sharing.
Thank you for the cool design. I cant wait to give it try
- david jordan
Looks great, thank you.
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
thats freaken sweet.wow....thank you
Thanks so much this will look awesome at the shop.
