More Easyscriber…
Polargtx
More Easyscriber…
Post by Polargtx »
A couple more I did this weekend …
Umpy
Re: More Easyscriber…
Post by Umpy »
Those are fantastic! Nice job.
Do you mind sharing what the surface and prep is?
Thanks.
Those look great! Do you make the disc and base or do you buy those?
Polargtx
Post by Polargtx »
I make the discs by cutting them from 20 ga and prep with 3M scotch brite sanding pads. Then prime with black primer , after I do the engraving I shoot them with clear.
I would say you have the process well dialed in, thanks of posting. What software are you using to develop your work??
Sounds like a simple process and looks great. I see a lot of unique things being done with those scribes.
Sampson Jones
Post by Sampson Jones »
I assume you cut the disc out . Clean the disc up . Paint it . Clamp the disc down , engrave it .
I'd be interested on how you line the disc back up and clamp down to engrave . Pics of the process would help . Thanks
CandCNC electronics
Hypertherm powermax 65
Command Lineux
Super z 2
Inkscape and corel draw
I would say using the center of the file not X0 Y0
center location.JPG (44.88 KiB) Viewed 1496 times
I think if depends on the particular table/controller setup. On my Avid/Mach3 table, I would clamp the disc down, move the spindle/engraver so that it is centered on the disc, and then zero out my x and y. This assumes that when I drew it I had zero,zero at the center of the part. So just align the engraver tip to the original origin of the part, then zero out the x and y. Of course, it's always best to do a "dry run" just to make sure.
