Homemade 40 ton press brake
ch1085
Post by ch1085 »
Here is a 40 ton press brake that I built using my homemade cnc plasma cutter for use in my personal fab shop. Some specifications listed below:
• Adjustable hydraulic jack locations - jacks slide side-to-side for optimal positioning dependent on work piece width
• Spring compensated and adjustable gauge rods for consistent and accurate repeat bends. Compression springs prevent damage to the gauge system in the event that the stop point is exceeded
• Upper and lower bending dies built from cold rolled 1018 for a typically higher material hardness than the workpiece
• Adjustable width bottom die assembly using two 1.5 inch diameter cold rolled solid round rods
• Bending blade that can be cut into fingers to allow for box and pan bending operations. Ability to make custom dies that slide into the 3/4in tang slot
• Hydraulic jacks plumbed together for simultaneous operation but can also be operated individually for level adjustment
• Adaptable, adjustable, modular, and easily repairable design utilizing minimal welding of components onto the main frame
Jason@bc
Re: Homemade 40 ton press brake
Post by Jason@bc »
Very nice! It's a very rewarding feeling to be able to build tools and stuff you need yourself.
Sweet :Love :Love looks like someone will get getting a Pizza oven for Christmas :Like
bigcreek
Post by bigcreek »
Awesome build!
ch1085
Post by ch1085 »
Jason@bc wrote: Fri Nov 25, 2022 10:03 pm Very nice! It's a very rewarding feeling to be able to build tools and stuff you need yourself.
Thanks! Fully agreed, there’s no better feeling than using your own home built tools. Especially when using them to build more home built tools!
ch1085
Post by ch1085 »
bigcreek wrote: Sat Nov 26, 2022 12:43 am Awesome build!
Thanks! If you want to see more details on the build, I have a video showing the entire CAD design through fabrication process. Search YouTube for user “custom fabricated”
ch1085
Post by ch1085 »
acourtjester wrote: Fri Nov 25, 2022 10:24 pm Sweet :Love :Love looks like someone will get getting a Pizza oven for Christmas :Like
Yup that was my homemade pizza oven in one of the pics. I have a video showing the entire pizza design and fabrication process here:
And a video for the press brake:
I say those look pretty good on your resume, if you wanted to get into metal fabrications some day. :Like :Like :Yay
Thanks for the share.
Scratch
Post by Scratch »
I dream of a press brake like that someday.
I dream of wood fired pizza pretty much everyday!
I’ve been toying around with the idea of making a pizza oven, how long does it take to bake a pizza in yours?
Excellent work on both press brake and oven!! Looks like you've got a great "hobby shop" going there. I built a smaller 20 ton press brake using the Swag Offroad kit, and it works great for my purposes- mainly brackets and such for automotive work. Thanks for sharing your work and videos.
I have subscribed to your Youtube channel for future reference.
Wow! Well done, very impressive :Like :Like
ROKCRLER
Post by ROKCRLER »
Nice work... ive watched the press video probably a few times now... impressed every time.
4x8 Dynatorch
PM85
~Mo~
1MORECUT
Post by 1MORECUT »
Nicely done.
ch1085
Post by ch1085 »
Scratch wrote: Sat Nov 26, 2022 10:09 am I dream of a press brake like that someday.
That oven gets to over 1000F and can cook pizzas in less than 90 seconds
larrycameron44
Post by larrycameron44 »
Did anyone have a dxf for the pizza oven I can buy?
Larry Cameron
RusticMetalArt NZ
larrycameron44 wrote: Mon Feb 13, 2023 9:11 pm Did anyone have a dxf for the pizza oven I can buy?
Larry Cameron
RusticMetalArt NZ
Hey Larry, I believe he offers the files for sale on Etsy. Try sending him a PM.
Post by tnbndr »
Can someone clarify for me please? Does two 20 ton jacks side by side really make 40 tons or is it 20 tons just evenly distributed?
SegoMan DeSigns
Post by SegoMan DeSigns »
Your answer is 40 ton total that is evenly distributed. if they were end to end it would be 20T only, Bends are rated in tons per foot off of the following chart:
Post by tnbndr »
So if a third jack was added it would be 60 ton?
I understand the chart for tonnage required and optimum die size.
SegoMan DeSigns
Yes you can stack as many as you like if your frame work will handle it. With everyone wanting a CNC machine there is a lot of the older mechanical units out there that could be retrofitted with hydraulics.
Post by tnbndr »
SegoMan DeSigns wrote: Thu Feb 16, 2023 1:15 pm Yes you can stack as many as you like if your frame work will handle it. With everyone wanting a CNC machine there is a lot of the older mechanical units out there that could be retrofitted with hydraulics.
I've been looking. I just didn't think the math worked that way so I passed on a 60ton not too long ago. I am leaning toward just building one with hydraulic cylinders anyway.
SegoMan DeSigns
A power pack with solenoids and rams sure make stroke control a lot easier.
here is a post from the welding site showing a 40 ton press brake a member posted. lots of info shown in the post as it was built using a hydraulic cylinder and pump.
https://weldingweb.com/vbb/threads/7123 ... ress-Brake
ch1085
Post by ch1085 »
I can cook a pizza in less than 90 seconds in my oven. It teachers over 1000F inside
SegoMan DeSigns
Another Build. there is a few more on this forum that can be found with a little searching:
https://www.pirate4x4.com/threads/press ... a.1725178/
