Ohmic Sensing for the hardcore DIY'er
rbmgf7
Post by rbmgf7 »
I managed to integrate a CandCNC ohmic sensor to signal my ESS for probing. It's not hard and only $75 if you want the option.
Z-Home wire to +5VDC and COM to your input of choice. Doesn't make sense to me because COM I originally had to Ground and Z-home to the input. Didn't do anything. Maybe mislabeled?
YouTube video
Re: Ohmic Sensing for the hardcore DIY'er
Post by tcaudle »
No, Common input on a CanCNC system it was designed for is NOT ground
Nacs Fab
Post by Nacs Fab »
To the Original Poster, can you explain what type of system you have? I would love to install ohmic on my G540 with LCTHC but I believe I cannot with this torch height control.
G540 with LCTHC by candcnc
all built... by me...
rbmgf7
Post by rbmgf7 »
ESS running Mach3. Doesn't matter what system you have. If it accepts 5V logic, then it works on anything.
ForceDesigns
Post by ForceDesigns »
I know I am digging up an old post but this did not work for me. Just got my feather touch in and cannot for the life of me getting the input to show in Mach3. I believe that the voltage is too low, though the light comes on for the input (measured 2.7v). No matter how it is configured in mach it still doesn't trigger. Any advice or input would be greatly appreciated.
Home Built 4x4 CNC Plasma Table
Ethernet Smoothstepper
C25 BOB
MiniTHC
Hypertherm Powermax 45XP
Software: Mach3 and Sheetcam, Solidworks 2019 for serious design work and Inkscape for signs
islander261
Post by islander261 »
Hi
I managed to use the Feathertouch box on both my Torchmate 3 and LinuxCNC system. Sorry I can't help I have never used Mach. There should be plenty of people here that can help because all the CandCNC stuff from old (including the Feathertouch box) ran using Mach.
John
john78
Post by john78 »
I used it on my DIY table. Stand alone for ohmic only. Have a separate limit/home switch assigned to a different input.
4x4 Plasma Table
Mach3 with CSMIO/IP-S
CandCNC Feather Touch & LCTHC
Hypertherm PMX 1000
Homemade Rotary Plasma Attachment
