Fallen Soldier Memorial
steelfx
Post by steelfx »
This is scaled to cut best at 4' wide...
fallen_soldier.dxf
med-pac
Re: Fallen Soldier Memorial
Post by med-pac »
Nice work Bill!
Think I'll have to cut this out for the local VFW.
Mike
DumOleBob
Post by DumOleBob »
Best I've seen! Thanks!!!
AIRFLOWKID
Post by AIRFLOWKID »
Bill,
If you were to apply a patina to this what would be your means of application? I use a 55 gal. drum and dip piece into drum, but what is the best way to do larger pieces such as the one above? Do you use an aspirator to apply? Ordinary spray bottle? brush?
Thanks for the info. Tim Red Robin Creatives
steelfx
Post by steelfx »
AIRFLOWKID wrote:Bill,
Hi Tim,
I'd highly recommend a Viton Seal Pressure Pump for the Copper FX Base. I have those in stock & on my 'Supplies'
page of my website. http://www.steelf-x.com/Supplies.html
The trick is to pre-wet (with water) the polished side of your larger piece, prime your pump-sprayer with about 35-40 pumps, spray (starting at the top) with a fine mist of Copper FX.
Flush/Rinse with "Shower" setting on an adjustable spray nozzle very quickly & thoroughly. You don't want the Copper FX
to stay on the piece more than 3-5 seconds.
Now, you'll be ready for subsequent patinas, e.g. Pewter FX (which will give a bronzing effect) and/or Torch FX for reds and blues.
thanks,
Bill
AIRFLOWKID
Bill,
Thanks for all the info.I will be place an order in the near future. You are a great resource for me to learn more and succeed in business.
Thanks so much, Tim
Loyd
Post by Loyd »
Bill, From a former Marine, thanks for the file. You are a craftsman.
Loyd
steelfx
Post by steelfx »
thanks, Loyd! Thank YOU for your service to our Country! bw
Ray Mighells
Post by Ray Mighells »
Thanks for the file I will put it to good use for a close friend of mine who lost his son in Iraq.God Bless you and all the Vets out there.
Smoke
mdoffroad
Post by mdoffroad »
GREAT WORK........Thank you for sharing!!!
GWS.Arkansas
Post by GWS.Arkansas »
For some reason When I opened it it was so small I couldnt see it . I tried to inlarge it but would not work. Can anyone give me a hand opening this file. Please . I am using Corel X3. Thanks to all
FiveORacing
Post by FiveORacing »
GWS.Arkansas wrote:For some reason When I opened it it was so small I couldnt see it . I tried to inlarge it but would not work. Can anyone give me a hand opening this file. Please . I am using Corel X3. Thanks to all
That's odd, mine came out 46 x 43.
fallen_soldier.dxf
GWS.Arkansas
Not sure what I am doing wrong but it still doing the same thing. But thanks for trying again.
It opened up 46" X 43" for me, also. I resaved it from MasterCam and am posting it here. Hope it helps.
FALLEN_SOLDIER-2.DXF
GWS.Arkansas
not sure what you did but it worked that time. I dont know crazy computers. thanks for the file and the help
lucky7sg
Post by lucky7sg »
thankyou will work perfectly for a piece I have to design for our veterans memorial garden
