Weird one that is driving me nuts.
When I import a file that I drew in draftsight directly into sigmanest the parts are very small. An example is a square piece that is drawn at 12"X12" in sigmanest it's .4724x .4724.
Same exact drawing I import into arbor image and re save as a dxf and then into sigmanest the part is 12x12 like it's supposed to be.
I'm sure its something easy but I haven't been able to figure it out.
I also drew the same part in draftsight from another computer and saved it to dropbox and imported into sigmanest and the part is correct so I'm assuming it's a setting on this version of draftsight.
Chris
Draftsight to sigmanest parts are very small
- cstroke
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
Re: Draftsight to sigmanest parts are very small
Well I don't know about Sigmanest but those number fit if you are drawing in inches and saving in MM see attached.
- cstroke
Hmnnnnn. weird LOL..
I wonder why it's set up that way.
I never gave metric a thought.
Chris
Edited: Ok went to draftsight and under format it was set as millimeters, changed to inches and I'm good to go. Thanks for kicking my brain into gear, sometimes it takes more than one kick to make things happen.
Thanks again.
Chris
Thanks again.
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
You are not alone we all have days when things are off
This question has come up many times with other programs too.
