Newbie needshelp with commandcnc
CommandCNC related questions, tips and topics can be posted here
dsanford55
Post by dsanford55 »
i suppose the 1st problem is my compressor needs time to reload before making long cuts.
Thus I need to either stop or pause and let the compressor catch up to the plasma table.
Seems like this should be a simple process however, can't seem to get there.
How do I pause or stop, let the compressor reload, and then start cutting from where I left off?
Thanks in advance for your help!!!!!!!!
dsanford55
Re: Newbie needshelp with commandcnc
figured it out
Othog
Post by Othog »
How did you do it?
dsanford55
i hit the pause button, reload the compressor, then hit resume.
this works till i get an electrician out here to upgrade my service.
Post by tcaudle »
Just an FYI. An M1 call in G-code does the same thing as pause. You can insert code "snips" between Operations in SheetCAM. You can also put inqa general delay in the form of "G4 P## where ## is in seconds. then it would pause, wait then start up again automatically. Using the layers and operations in SheetCAM to give you more control over you cuts can have distinct advantages.
Return to “C&CNC CommandCNC”
