Hypertherm 65 machine torch
wweisiger
Post by wweisiger »
I got the machine torch hooked up, and the plug and play wire too. Testing on a 2" x 2" square. Torch fires up, but keeps stoping in the exact same place. Error say "torch signal lost." Any ideas?
sphurley
Re: Hypertherm 65 machine torch
Post by sphurley »
Sounds like you are not getting Arc OK feedback.
It would help to know: machine type, software running machine, etc.
Platform CNC Plasma table
CandCNC Ethercut IV DTHC
Hypertherm 85/CPC/RS485
Miller 350P
Miller Dynasty 280DX
sphurley
Post by sphurley »
I think Jim Colt can take a swing at this. He has a Plazma Cam system. Works fine with hand torch. Sorry I'm not a Plasma Cam guy.
Miller 350P
rdj357
Post by rdj357 »
The software is telling you that the torch signal was lost - you have to determine if that is because the torch stopped firing or the software didn't catch it.
Make sure the voltage divider in the plasma is set to 21.2:1
On settings, Machine Control tab - Cutting Signal set to Min 1.9, Max 12
Another common source of this problem is that the torch has stopped firing because of something else. USUALLY it is a lack of air supply to the plasma. If there is a yellow light on the plasma when it stops, look for the code and use your Hypertherm manual. The low air pressure is a soft fault, meaning that it will self reset and when you try to run it again it will get started and fault on low air again. You should have 90-135 PSI at the inlet of the plasma WHILE the torch is cutting at all times.
